Home > Maintenance & Modifications > Rear racking / storage
Likeomg
Looking to see if anyone has come up with something similar to this? or has a better idea for me to use...
I need to transport a object that's 1.6m x 30 x 25 and weight's about 15kg in the 90 Puma about 1000 miles round trip through Germany (inc possibly a trip around the world famous ring)
Now it does just fit jammed diagonally across the back but it's less than ideal, limits storage for other things and it's quite a funny shaped thing that will move around and do damage to the interior / itself
My plan is to create a rack in the rear that picks up on the M6 tie down points in the rear such as my wonderful drawing in paint shows lifting the object above the passenger seat and giving me the length that the 90 doesn't have in the rear
Other option is to take the seat out since im rolling solo however will be meeting up with friends and the passenger seat may be useful later on...
Has anyone done something similar to this before?
The idea is to create a platform for it to sit ontop of and be strapped down to.
I plan to make it out of 30 x 30 aluminum box, and the tie down attachments will be 5mm aluminum with the 30x30 welded to it.
I don't really have any pickup points on the window side of the car, maybe i can clamp to the bulkhead removal bar?
It's also a bit of a pain, as i'm away with work so i can't use the truck to measure off / visualise, i will have a week to build this contraption from getting back to the trip starting.
Post #1072009 22nd Jul 2025 8:30pm
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
My biggest concern is that the object being carried, may slip it's bonds, and become a projectile either forwards through the windscreen or backwards though the rear screen - either way bad. Is this object making a return journey or is it one way?
Have you considered going low-level and passing it over or onto the Cubby Box (blankets, pipe lagging, foam to protect item & interior) with sutable tie downs and securing?
The lower the object, the less gravity can have an effect, the lower the risk?
I do have to appologise, since I have a 110, and and a slim'ish 5'7" so have few problems fitting myself or objects in. Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #1072013 22nd Jul 2025 9:02pm
Likeomg
It’s going both ways…
I’ve done it over the cubby before but I’m 6ft 4 and it rests right on top of the cubby where my elbow would normally go, it’s okay for maybe a hour but not for this far
I used to always go in the rangie but fancy a defender road trip for a change
Post #1072014 22nd Jul 2025 9:06pm
DSC-off
It sounds like a job for a roofbox, with foam cut to protect the contents and a pair of roofbars.
Remove the box for a spin round the track.
Easily fitted to another vehicle to transport the same item.
Post #1072015 22nd Jul 2025 9:08pm
Likeomg
Problem is the ferry, it almost doubles in price to have anything on the roof my plan is Hull - Rotterdam, drive down to Munich and i have a weeklong ship handling course in Rotterdam on the way back, the hotel car park is 2.1m in Rotterdam so I just squeeze under with my roof rack...
& The item in question is actually a RC boat, given it's value id much rather have it inside.
That's the biggest of the 4 I'm taking to a race down near Munich, with 3 Pelican cases full of tools / spares / Lipo batteries all the other boats slot inside fairly nicely.
Post #1072035 23rd Jul 2025 6:51am
Likeomg
I suppose i could also brace it against the other side of the tub,
and then this gives me another place to lay the other hulls for transporting...
Could put some plywood over the top too however not sure how my big sub would get on with it
Post #1072040 23rd Jul 2025 8:03am
excossack
Could you remove the seat and put this in the back, slide in your RC boat and then when you need the seat re-fit? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1072041 23rd Jul 2025 8:15am
Retroanaconda
I have a high level shelf for camping stuff - would something like that work?
Post #1072042 23rd Jul 2025 8:16am
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Could I ask where you got the high level shelf?
That would be really useful Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1072044 23rd Jul 2025 9:29am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Flatdog do a number of internal storage solutions: https://www.flatdoguk.com/search.asp?types...+Solutions
Post #1072048 23rd Jul 2025 10:06am
Retroanaconda
I made it, but off-the-shelf solutions are available as per above.
Post #1072051 23rd Jul 2025 11:20am
Likeomg
this would actually be perfect, however i have windows in the rear now with alcantara window surrounds and not many securing points,
I know there is the MSS option but its 400 quid+ and i'd probably have to cut and modify it anyway
Post #1072055 23rd Jul 2025 12:07pm
excossack
Could you build a frame to sit in the back to mimic the above setup? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1072060 23rd Jul 2025 1:33pm
Likeomg
Possibly, However i guess i'd have to go over the top of the alcantara side pieces like the MSS option.
Which would be a little more complicated / involved
I think the rectangle box design probably will work, i can make it out of 30x30 or 40x40 aluminium box and incorporate some ratchet strap's to fix the boat in place.
My only concern would be when cornering to the left would the frame bend and boat topple to the right... Not just on the 'Ring but general driving.
Does anyone know the diameter of the bulkhead removal bar? Thinking i could incorporate a "roll cage clamp" and that would be some bracing for the left side of the rack...
Post #1072075 23rd Jul 2025 4:13pm
excossack
Or a dog cage. Luggage inside. Miss england secured to the top?
How big is Miss England? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1072080 23rd Jul 2025 5:35pm
