Home > Maintenance & Modifications > Brakes! Or lack of….
rich_allen
United Kingdom 2002 Defender 90 Td5 HT Coniston Green
Evening all… hoping I can rack someone’s brain or there are some brake gurus out there..
This one has me stumped!
2002 Defender 90 TD5..
The brakes have been pretty rubbish for quite a long time but now seem to have completely given up..
My pedal goes straight to the floor with almost no braking force applied. It does not matter if the engine is running or not, or if it’s moving or not…. It’s the same in all conditions.
It has larger 110 rear calipers, LOF 6 pots on the front. Braided lines all round, I’ve replaced the master cylinder twice (to rule out the first one being faulty - both genuine TRW)
Ive just replaced the bias valve today and rebled about 6 times and still the same…
I fitted the LOF brake booster kit to see if that made a difference but no… put the original booster back on today just incase and still the same…..
No fluid is being lost, no visable leaks…
HELP!! 😂
It’s the most basic of systems but I can’t get a pedal!!
Post #1071755 19th Jul 2025 9:16pm
miker
Is there a difference between 90 and 110 master cylinders normally?
It kind of sounds like you may have a lot more slave cylinder capacity (bigger 100 calipers and 6 pot fronts) but no more fluid being pushed to them....
Just a theory mind you.
Post #1071761 19th Jul 2025 10:13pm
landy andy
Can you manually bleed them?
Are you able to get fluid out of bleed?
What does pedal feel like, any resistance?
Have you adjusted the brake actuator rod?
Are your wheel bearings all spot on?
Post #1071767 20th Jul 2025 2:36am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
Have you checked the seals in the slave cylinder?
Jim
Post #1071768 20th Jul 2025 4:25am
jst
Insufficient travel in master cylinder. Increase pedal stroke. Will need to displace fair amount of fluid to push all pistons in.
How are you bleeding it? Pressure kit? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1071771 20th Jul 2025 7:30am
rich_allen
I did wonder this but even if this was the case surely I’d have some sort of pedal?
Post #1071789 20th Jul 2025 12:57pm
rich_allen
Been using a pressure bleeder, fluid comes out the nipples lovely, just as you’d expect. I’ve probably flushed 2-3 litres through…
Very little resistance on the pedal… a little but not a lot. Bearings all feel nice and tight.
Haven’t touched the brake actuator rod, (what would I need to do to that, does that make a huge difference?)
Post #1071791 20th Jul 2025 1:00pm
rich_allen
Yes, pressure kit, even with the amount of fluid needing to be pushed I would have thought id have some pedal.. I’m sure there are plenty out there with bigger brakes and normal master cylinder?
Post #1071792 20th Jul 2025 1:02pm
landy andy
If you manually bleed them, can you get a good squirt of fluid out?
That is what I would be trying for
Post #1071821 20th Jul 2025 7:19pm
jst
I have uprated front 6 pot calipers. I would be checking your getting sufficient stroke from the mc to displace enough fluid.
But yes you should have something from any press.
Try the manual bleed option.
Calipers right way up? Nipple at top? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1071839 20th Jul 2025 10:18pm
rich_allen
Yes, calipers all correct, have been fitted for a few years… brakes have just got gradually worse over time to now being non existent..
Will try the manual bleed.
Can anyone tell me how to check/adjust the actuator rod
Thanks
Post #1071863 21st Jul 2025 9:33am
If you pump the pedal does it go hard?
Assuming you have no leaks then either the m/c doesn't displace enough fluid to apply the brakes, or the m/c is leaking internally and doesn't apply pressure the brake line. If the former, pumping the pedal should give you brakes, if the latter it won't.
Post #1071870 21st Jul 2025 10:40am
jst
Thanks
check if you can get a pedal first and manual bleed it. unlikley to be rod now as you state that setup has been fitted for a while.
so they were working with that caliper setup no problem then you got more and more pedal movement for less and less braking and now with brake pedal pressed all the way in the vehicle brakes are not applied? is that correct?
assuming Yes, and confirm it was like that before MC was changed ?
assuming yes to 2nd Q then with new MC fitted is made no difference?
if you are not using fluid, its the same setup as before, its the same no pedal with 3 x MCs and no brakes then there must be air in it.
If you had sticky pistons you would have a pedal.
if you had pressure you would have a pedal
as you dont have a pedal you dont have pressure and as your not using/losing any fluid then there must be air in it. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1071907 21st Jul 2025 3:14pm
Roverdrive
I would have thought with 6 pot calipers you need to displace more fluid so would need a larger master cylinder. What do LOF recommend?
That being said if it was working before, it must be something else causing the present problem.
Check the wheel bearings have minimal play, and also check the run out of the disks in case they are distorted and you are getting pad knock off, where the pads are pushed back further from the disk.
However if you can't pump the pedal up, it is unlikely that.
Good luck Mike
110 CSW
Post #1072002 22nd Jul 2025 6:58pm
jst
Alot of the 6 pots have small dia pistons not much in it two large std pistons or 3 smaller dia pistons SA wise. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1072025 22nd Jul 2025 10:18pm
