Home > Puma (Tdci) > Constantly bleeding brakes
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
Hi guys
Bled my brakes a few times now and got them working great.
Defender sits in the garage a week and they need bleeding again. Pedal goes straight to the floor.
No fluid leaking, but obviously air is getting into the system some how
Any ideas how to solve please ?
Thanks
Post #1071128 9th Jul 2025 4:50pm
MK
A friend had the same issue. He replaced the master cylinder (or its seals). Puma 110" SW
Post #1071131 9th Jul 2025 5:03pm
jst
Re: Constantly bleeding brakes
Kevlar wrote:
Hi guys
Thanks
When you say air is getting in is that because your seeing it come out when you bleed them or is it an assumption.
If you have air coming out then is it at all.four corners?
If no air but they improve with pedal pumping then possible mc. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1071153 9th Jul 2025 10:18pm
revd
I had a metal brake that ran along the back axle on my old 90 - it had partially chaffed through and was porous but not enough drip fluid
Post #1071157 9th Jul 2025 11:20pm
Kevlar
Yeah I’m getting air bubbles on the front brakes every time I bleed them.
The back brakes no bubbles.
Thanks for replies so far,
Kev
Post #1071186 10th Jul 2025 3:53pm
landy andy
Both fronts?
Post #1071188 10th Jul 2025 4:55pm
Kevlar
Mostly the front right, furthest from the master cylinder
Post #1071190 10th Jul 2025 5:36pm
jst
I'd check union's on copper pipe and flexi, if problem persists replace copper pipe. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1071205 10th Jul 2025 10:42pm
Kevlar
I checked everything I can reach, no signs of leaking on the pipes, unions or hoses.
I will bleed again and hope it lasts a while.
I am surprised air is getting in but I can’t see any fluid leaks or reservoir level going down.
Post #1071302 12th Jul 2025 3:11pm
jst
How are you bleeding it? Vacuum?
Leaving pressure bleeder on it overnight is a good way of highlighting failure points.
Air is either not all coming out or its getting in. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1071307 12th Jul 2025 4:19pm
landy andy
Is it an ABS vehicle?
All the pump and fittings look ok?
Post #1071310 12th Jul 2025 5:25pm
Kevlar
Yes it’s abs, I managed to turn one of the fittings on the abs unit a little bit.
But there was no signs of leakage around the fittings.
Going to bleed all brakes tomorrow and see how long it lasts.
Post #1071318 12th Jul 2025 7:01pm
Any signs of any leaks around the PRV? (If fitted?). ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1071349 13th Jul 2025 4:53pm
Kevlar
Can’t see any leaks anywhere, not from the brakes anyway 😀
I just bled them again, loads of air from front right caliper.
Brake pedal is solid now, going camping tomorrow so I will see how brakes perform.
Post #1071590 16th Jul 2025 5:54pm
landy andy
Try clamping flex pipe to that one calliper and see if air coming in that corner
Post #1071601 16th Jul 2025 8:03pm
