![]() | Home > Puma (Tdci) > ScanGauge II Oil Temperature |
Doobsn Member Since: 18 Jan 2023 Location: Bavaria Posts: 14 ![]() ![]() ![]() |
Hello,
I installed a ScanGauge II in my 2.2 Defender and activated Motor Oil Temperature. Has anyone possibly checked the readings from the ScanGauge II to a seperate installed sensor? I get up to 130 Degrees Celsius Oil Temp at 120 Km/h on the Highway. Maybe someone of you has an answer for me. Cheers Tobias |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
I'm trying to remember what my oil temp runs at in my 2.2...
I think it runs about 104 deg C on average when its cruising in 6th... The coolant will be around 94 deg C... That's ball park and can vary a bit with load.. There is a limit to the power output if the oil temp or fuel temp reach certain values but I can't remember what they might be... 140 for the oil seems to ring a bell, but can't be sure.. |
Hi Andy63,
thank you for your answers. So it seems my one is running a bit hot. I am not sure if there is a real sensor or the ScanGauge is calculating something, but with your answers there is a sensor somewhere. Cheers |
I think its a combined oil level and temp sensor.. located close to where the turbo oil return goes back into the sump..
It seems high on the face of it, but so much is dependant on load and your cooling system temp.. And the temp of 140 I mentioned is from memory and may have been related to the max temp that the normal oils are suited to run at.. I'll have a look at my ws manual and see if its got anything.. |
Here you go..it would appear the old memory was good on this occasion
Hello Andy63,
thank you! 140 is high and I have some room to manouver. I will look into it to bring the temperature down. Cheers |
That's a low coolant temp for the conditions you are describing in my experience, but regardless the temp differential between coolant and oil temp would point to the oil cooler not functioning efficiently, and one reason could well be a restricted coolant flow..👍
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
removing the oil cooler thermostat may help if that stat is faulty , noting on later Puma’s the oil cooler thermostat was not fitted, I.e an empty oil cooler thermostat housing was fitted instead. Changing the oil cooler thermostat is easy to do with basic hand tools, however it is a main drain point for the coolant so you will loose most of it and need to refill with a lot of coolant and bleed the system after. |
glassman Member Since: 30 May 2025 Location: Cape Town Posts: 9 ![]() ![]() |
Thanks guys. Drove today on oil temperature keeping it below 125c. Rather painful at times but it got us to our next stop.
We have time in the morning tomorrow to remove the thermostat and do the fluids. Thanks for the heads up on these. Hope it solves the issue. It would really be helpful and greatly appreciated if someone could send through pictures from the manual showing the stat removal and replacement. I don't have access to mine while away. |
