![]() | Home > My New Defender (L663) > Hello from a first time defender owner. |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785
With a IIDTool you can enable ACC.
I think there’s now a way to set the car to remember your preference on the ADAS stuff too - i.e. stop it defaulting back to fully on each time you start it. |
| Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 113
As above if you get yourself a gap IID you can do quite a lot
Have a look here https://www.defender2.net/forum/topic89347.html 26MY SE 90 in Woolstone green on order. 24MY HSE X-Dynamic 90 Carpathian Grey |
| Mr Mike Member Since: 12 Jun 2025 Location: Scotland Posts: 8
Thanks both. I haven’t looked into this in too much detail, though on first glance it looks like the switches for adjusting the distance are missing. I was told they would light up once activated ‘though they have no logo at all. I can see the other switch logos, lit or unlit. They are not visible at all where the switches should be.
I haven’t checked for a radar, though I’m assuming that there may be stuff not available or accessible on mine as it’s a commercial version. Though if there is anyone out there with a commercial 90 who knows differently I’m all ears |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3526
Have you managed to disable the "door open" bong?
| LandyMax Member Since: 10 Jan 2024 Location: Worcester Posts: 18
My 90 commercial has it. I think the sensors are behind the Land Rover badge on the grill. |
I’ve not consciously disabled it, though it’s not a bong amongst many I’ve identified yet |
Thanks Landman I’ll take a closer look a5 some stage and see what’s happening with it. |
