![]() | Home > For Sale & Wanted > [For Sale] TD5 green top injectors |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I have 10x TD5 green top injectors surplus to requirements.
5 of them came from my vehicle (circa 140k miles). All were functional when removed a couple of years ago but one has some slight pitting to the seal face which meant it got through an injector seal washer every 12months or so. The second set I purchased used when i fitted a new head to my engine. Ran them for a few thousand miles but one of them had issues with the spray pattern and ended up with a hotspot which damaged the egde of the piston crown and the bore. Swapped out the whole engine so havent reused any of them. I have kept a record of all the codes so should be able to tell the faulty two easily enough. All have been stored with a light coating of oil in individual plastic bags with some 3D printed protection cones to keep the business end clean. Might be useful to someone for spares/refurb or core exchange purposes. Ideally dont want to have to post. Located just south of Carlisle, Cumbria. £40 for the lot Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
All look pretty much identical so here is a picture of thr first out of the box
![]() ![]() Click image to enlarge ![]() Click image to enlarge 02' 110 TD5 Double Cab Rebuild Thread |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 161 ![]() ![]() ![]() |
Yes please!! Will pm.
