![]() | Home > Td5 > Overheating sound? |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1316 ![]() ![]() ![]() |
15min of Td5 action barely gets mine to operating temperature..
I would start with confirming of your engine is in any way overheating. Get a cheap infrared thermometer and start taking some readings. It could be what you hear is the exhaust where maybe a stud has come loose (broken) which is pretty common and can be a pain to correct. If so I recommend you get the exhaust manifold skimmed (milled flat), they tend to warp/bend |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 588 ![]() ![]() ![]() |
The centrifugal oil filter on the TD5 sometimes makes a noise (spinning down) when switching the engine off.
Maybe that's what you hear? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17933 ![]() ![]() ![]() |
It could be a warped exhaust manifold moving, especially if one or more stud has failed.
rsms Member Since: 12 Jan 2013 Location: Home Posts: 38 ![]() ![]() |
Very good tips! Will check "heat print" with IR thermometer and if all the manifold studs are there and not loose.
The centrifugal filter spinning-down sound can also be heard but the new sound is different. Today I listened to the running engine sound again (bonnet-up) and the strange new noise can also be heard now and then when engine is running - time to do some homework. Thank you - will reply back with findings. |
