![]() | Home > Maintenance & Modifications > Squealing Rear brakes |
Mike2a Member Since: 20 May 2024 Location: Devon Posts: 15 ![]() ![]() ![]() |
Hi all,
Have some issues with ridiculously noisy rear brakes. It all started when I replaced the pads with new yellow terraferma pads. When I did this I stupidly discarded the shims as the pads had a rubber backing pad. I cleaned up and cpper slipped the edges of the pads as I have done a thousand times before along with the pins. Initially I thought the squeeling would bed in but it hasn't over the last 400mi. So new shims to be ordered, However I can only find springs and pins for pre 01 110's. https://www.lrparts.net/da4105-rear-brake-...-pads.html Would these fit a 13 plate? Also has any one else had issues with terraferma pads? Have I seen my self off and just gone with Brembo as normal? Cheers Mike |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18009 ![]() ![]() ![]() |
There is a clue in the correct name for that kind of shim - "anti-squeal shims"!
Their purpose is to lessen the pressure applied to the leading edge of the pad and this is achieved by means of the cut out in the shim. Virtually any type of pad will squeal if you omit these shims. The partial bungy coating on the back of the pack supplements, rather than replaces, the shim, and helps reduce high-frequency vibrations. |
Thanks for the replies, I have the new bits. Here's hoping it now goes away.
