Home > General & Technical (L663) > Original Vs Aftermarket
SimonMac
Hi all,
I’m new to the forum, and first time Land Rover owner. I picked up a MY22 90 D250 X-Dynamic SE in Santorini Black a couple of weeks ago. So far so good and loving it.
Even though the spec is okay there’s still a few ‘bits’ missing/ desirable. I wanted to fit the roof rails but at circa £700 not cheap for the genuine Land Rover ones. I’ve seen plenty of aftermarket alternatives that are considerably cheaper, closer to £200 - £250.
Does anyone have experience of alternatives? Am I getting what I pay for or are they just as good? If aftermarket is just as good is there a particular brand to chose or avoid?
Thanks.
Post #1069278 8th Jun 2025 8:41am
Defendit..
Netherlands
Welcome Simon, No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1069312 8th Jun 2025 6:16pm
SimonMac
Thanks Defendit
Post #1069313 8th Jun 2025 6:24pm
lightning
See if you can find some second hand OE parts, l picked up some "as new" OE side steps for half the new price.
Have a look at the for sale section of this forum, or you could try a wanted advert.
Post #1069314 8th Jun 2025 7:04pm
SimonMac
Thanks lightning, I’ll take a look
Post #1069370 9th Jun 2025 7:46pm
XplusYplusZ
Sorry, I don't have any input on sourcing cheaper options..
I'm sure you'll have found this already, but just in case - powerfulukltd are very helpful on the fitting process:
https://www.google.com/search?q=defender+l...r979Y,st:0
Post #1069564 12th Jun 2025 9:59am
Co1
I’ve got aftermarket roof rails. They fit just fine and you can’t tell the difference.
Post #1069616 13th Jun 2025 6:38am
SimonMac
Thanks XplusYplusZ - PowerfulUKltd has become my new obsession - Simon makes a good video, everything explained really well.
Appreciate the assurance Co1 - Thanks. Which ones did you go for in the end?
Post #1069617 13th Jun 2025 7:05am
Crazymind
OEM isn’t always the best option, but in this case, the OEM rails are clearly well-engineered. You can tell that time and effort went into their design and the selection of the right supplier.
They also provide a single point of contact for any accessories you choose to install, which gives me peace of mind knowing that they’re built to OEM standards.
While aftermarket copies may look identical, we can’t be certain of their durability or how they perform under stress. Have they even been tested under extreme conditions? I sometimes carry 120–130 kg on the roof, and that’s not a risk I’m willing to take.
That said, everything else mounted on my rails — like the roof rack, ladder, boxes, and molle plates — is not OEM
Post #1069620 13th Jun 2025 8:29am
SimonMac
Thanks crazymind. Appreciate the advice. Do I assume all OEM are the same then? My understanding is OEM means original equipment manufacturer, which I’m taking to mean same spec as the original and as Land Rover but perhaps without the branding and packaging? So if I bought something that was marked up as OEM it’s the equivalent to what you’d buy from Land Rover? I can’t recall if Britpart supply roof rails but I’m guessing they are as good as if they do.
Post #1069623 13th Jun 2025 9:13am
Crazymind
Ideally it would be great to know who is the supplier to the oem rails for Land Rover.
I have bought the bars for the roof rails from the oem supplier…Thule… half the price…
Mine came with rails so I didn’t dig enough to find the oem supplier…
Post #1069626 13th Jun 2025 9:26am
SimonMac
I’ll do a bit more digging. I might just go for the original in this case, like you say - tested and warranted. It’ll just have to wait that bit longer, I can then go for aftermarket accessories.
Post #1069627 13th Jun 2025 9:28am
SteveG
2005 Defender 90 Td5 CSW Belize Green
With the right fitting kit from Thule, you can fit the Thule aero cross bars directly to your Defender L663 roof. Obvious additional benefit of a lower height when the bars are fitted.
Post #1069665 13th Jun 2025 7:47pm
Co1
Not sure of the brand, but it’s the ones sold by Maltings 4x4.
Post #1069688 14th Jun 2025 7:14am
SimonMac
Appreciate that, thank you.
Post #1069714 14th Jun 2025 5:42pm
