![]() | Home > Technical > SP Rear quarter panels, seal lip too short |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683 ![]() ![]() ![]() |
If the lip you are referring to is the door seal retaining lip it doesn’t really matter as if done properly you will be drilling out the spotwelds and sandwiching the lip against the existing lip on the rear tub inner panel, which will still be full width.
