![]() | Home > Td5 > sensor located |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18017 ![]() ![]() ![]() |
It is underneath the exhaust manifold towards the rear of the block.
![]() Click image to enlarge I'm not sure if you are asking if the TD5 measures oil temperature as standard (it does not) or if you are asking if there is a aftermarket device that can replace the current pressure sensor and measure both pressure and temperature (I don't know of one). |
le scale Member Since: 29 May 2025 Location: occitanie Posts: 2 ![]() ![]() |
I'd like to know the oil pressure and temperature.
In any case, Thank you very much for your help. Pascal |
