![]() | Home > Puma (Tdci) > Puma 2.2 Nanocom outputs |
Hector Menendez Member Since: 22 May 2025 Location: Fuerteventura Posts: 11 ![]() ![]() ![]() |
Perfect! That makes sense! Thanks! |
So after a long time away from the car we did a smoke test and we had a proper leak on the egr outlet tube when it meets the inlet manifold. We teared a part half of the car to get there and fixed the leak, we run another smoke test and everything seems fine. Now we need to put everything back together, had to drain the coolant and move away a lot of stuff. Let’s see if this was the issue. I’ll come back here with the result! Thanks for the help! |
That was the issue, hard to find without a smoke test.
I should have done that first time before trying anything else, the car runs smooth now! Thanks for all the help everyone! |
