![]() | Home > Td5 > Exhaust gas temperature sensor / Pyrometer |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 393 ![]() ![]() ![]() |
The VDO info shows a part number NN03-320-264 but it is pretty pricey!
https://vdo-webshop.nl/en/temperature-sens...92733.html I am curious as to why you would want to know this info and what you intend to do with it once you've reported it? If you have a spare hole for an additional gauge wouldn't oil pressure, voltage, amps or a tachometer would be more informative. |
mark1200 Member Since: 09 Oct 2011 Location: peterborough Posts: 88 ![]() ![]() ![]() |
https://www.auberins.com/index.php?main_pa...ucts_id=66
This is what i used with a K type thermocouple, I had the parts from another project and thought to give it a try. I mainly use it as a way of saving fuel as the lower the temp the less fuel is used its suprising how hot the exhaust gets on a steep hill climb, 700.c + and less that 100.c coasting down the other side. After a long run and the turbo is very hot i always let the temps get below 200.c before switching the engine off preserving the turbo ! I have tuned td5 and i can get 35 mpg if i am really really careful lol.[/url] |
Mago Member Since: 25 Apr 2021 Location: Frankfurt Posts: 35 ![]() ![]() |
@Penflod, thanks for the tip!
I've found the VDO part now, too; a decent price. Which makes it all the more interesting to ask whether there's a suitable alternative... ![]() The (additional) gauge should be one of some more, like you mentioned. I just like the classic round gauges ![]() And maybe the TD5 has a bit more power, so certain values should be kept in mind. @mark1200, Yes, letting the turbo cool down is definitely a good idea! Regards, ![]() Defender 110 Puma 2.4 |
