![]() | Home > Puma (Tdci) > INJECTORS !!!!##### |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363 ![]() ![]() ![]() |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2526 ![]() ![]() |
If you have access to a ford discount then you may get the best price from ford, else more likely to get the best price if you buy a genuine Denso as they supply to ford and LR for your 2.4.
Just be aware there are a lot of fakes out there so choose supplier well. Also avoid reconditioned injectors, there’s quite a few reports of them failing quite quickly. Injectors will need coding etc, but a Puma Nanocom can do it. |
