Home > Puma (Tdci) > 2.4 TDCI PUMA - CANADA/ UNITED STATES
crs013
 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Hi everyone,
I remember the troubles I had when trying to source the correct and or compatible fluids for my 2.4 tdci 110. I've attached a non-exhaustive list you will need for maintenance - these fluids should be readily available in Canada and/ or the US.
Engine Oil Recommended Ford WSS M2C913-D (backwards compatible)
Motul 8100 Eco-nergy
What I've found to work well:
Amsoil Signature Series 5W30 Max Duty Diesel Oil
Manual Transmission MT82 GL4 SPEC ONLY:
Redline MT90 - 75w90
Amsoil GL4 75w90
Royal Purple MaxGear 75w90 (Says its safe for brass synchros)
Transfer Case & Differential Fluid: GL4/5 can use 75w90 or 140 depending on usage/load
Motul Gear 300 75w90
Amsoil SevereGear 75w90
Liquimoly Hypoid 75w90
Fuel Additives - Shell in the west coast of Canada. has premium diesel with a bit higher cetane(?)
However, I use Archoil AR6500. There's also Liquimoly Diesel 2002 Super Diesel Additive, and PowerService Diesel Fuel Additive.
Still hunting for the correct coolant and power steering fluid for the 2.4 Tdci Puma if anyone knows!
Post #1066672 30th Apr 2025 8:15am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
A stock transfer case has brass components. Use only GL4 oils. If you fit an Ashcroft ATB centre diff, then you can use GL5.
If you are in an area of Canada that gets cold, I really recommend fully synthetic oils for the diffs and T/C. It makes a huge difference in friction losses.
Post #1066703 30th Apr 2025 1:41pm
jbcollier
Power steering fluid? Just use automatic transmission fluid rated Dexron 2 or 3.
Coolant?
Shell Rotella ELC - not easy to find. Only seems to be available from distributors and specialist transport tuck suppliers. Comes pre-mixed.
Recochem HD Diesel ELC Concentrate - available at Canadian Tire and specialty truck suppliers.
Post #1066705 30th Apr 2025 1:53pm
crs013
Did some research and calling around. Motul Gear300 despite its Gl4/5 rating - can be used as it doesn't
have the usual mix of yellow-metal eating chemicals used to achieve that rating!
 2007 2.4 Puma 110 XS
Post #1066820 2nd May 2025 10:04am
Ianh
Regarding coolant, Land-rover use Delo XLC as their coolant. They rebadge it and sell it as their own.
Delo XLC is manufactured by Chevron / Texaco, so should be easy available in Canada and USA.
Post #1066821 2nd May 2025 10:33am
jbcollier
Sadly, large truck suppliers only and not easy to find at all.
Post #1066842 2nd May 2025 1:48pm
Bluest
The Puma power steering fluid is central hydraulic fluid, not ATF. I don't know what difference that makes in practise, but they are different products. 2007 110 TDCi Station Wagon XS
Post #1066859 2nd May 2025 3:06pm
jbcollier
It is common to use Dexron 3 in hydraulics.
The actual spec is Texaco Cold Climate 33270. There are various crossovers but you can use Dexron 3. Not just any ATF as some have friction modifiers, etc. YMMV
Post #1066860 2nd May 2025 3:41pm
TexasRover
Maybe you are overthinking this? These fluids are not all that unique and the machinery is not all that sensitive. You should able to find equivalent fluids based on specs that are close enough.
What is much more important is change interval and making sure the fluids doesn't run low.
I recall once having to change diff oil as water had gotten in (so inspection along is important). I did not know if it was a limited slip diff so I put put some standard oil in. After a few weeks I noticed juddering in turns so figured maybe it is limited slip. Drained and replaced the fluid with a limited slip oil and all was well. This was a fairly expensive Range Rover, but really it ain't all that special.
Post #1066872 2nd May 2025 5:45pm
