![]() | Home > General & Technical (L663) > Status Info within Pivi Pro/Dash |
| Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 113
You can definitely see tyre pressure in dash as for the other two I don’t believe you can🤔 26MY SE 90 in Woolstone green on order.
24MY HSE X-Dynamic 90 Carpathian Grey |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785
There’s a dipstick for oil level.
A GAP IIDTool can read oil temperature/pressure and just about every value held in the ECUs, but there’s no way of displaying it on the Pivi screen. Tyre pressures are shown on the drivers display. |
| lrFFM Member Since: 28 Sep 2017 Location: Frankfurt Posts: 76
Not all Defenders have dipsticks. But I can check the oil level through Pivi.
| essentian Member Since: 02 Apr 2025 Location: East Mids Posts: 45
Yes mine has a dipstick, though one of poor design and hard to read IMO. Surprised about oil temp, will have to play around on the dash to find tyre pressures.
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3528
There was no way to display these things in the old Defender and it didn't seem to ever be a problem.
It did have a water temperature gauge, but there were basically three possible readings it would show. "Cold" "Normal" and "too late" |
Things don’t have to be a problem to justify change or improvement; quality of life & convenience are reason enough. We’re also talking about a vehicle (130) that starts at £84k.
The madness of £84k aside, this is the the pressure screen in the driver display.
Click image to enlarge |
| WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 182
My 200Tdi had an oil pressure gauge but it always seemed to make things up as it went along. Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
