Home > Off Topic > Weedkiller sprayer advice
AMBxx
My cheapo backpack sprayer now leaks and the pump bit isn't working properly.
Short of buying the same thing for Β£25 from Screwfix again, has anyone got any advice on a better option.
I use to 3-4 times per year to spray a paddock with SBK and driveway with glyphosphate.
Current one is 16L backpack. 20L would be far too heavy on my back.
Ideally, I'd have one I could fix to a trolley to wheel around rather than having nasty chemicals on my back. I've seen fancy ones that have batteries but I just need manual pumping.
Any advice on brands/models?
Post #1066465 27th Apr 2025 3:36pm
lohr500
I bought a Matabi 20L backpack sprayer over 20 years ago and it is still going strong.
No leaks and the spray valve mechanism can be fully stripped down to clean out any crud.
No idea if they are still made to the same quality, but I can't fault it.
It looks like they do a 16L version, although if you find a 20L one cheap, then you don't need to fill it fully. Mine has graduations moulded into the side.
At the time they were cheaper than the Cooper Pegler back packs.
Like you, I probably use it 3/4/5 times a year with a variety of weed killers around our small holding and dissolved Ferrous Sulphate for killing the lawn moss.
Post #1066471 27th Apr 2025 6:07pm
Cooper Pegler ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #1066487 27th Apr 2025 10:15pm
AMBxx
Thanks, I've order a 16L Matabi.
Cooper Pegler look like the Rolls Royce version!
Post #1066498 28th Apr 2025 8:14am
Indeed, they are pricey but quality is good.
Depends on use though, can be overly expensive if for some small jobs.
Thumbs Up ____\We|Will|Win/___
Post #1066556 28th Apr 2025 6:28pm
htb2
Wales
Cooper pegler, have 2 bought over 20yrs ago, earned me over 350k in that time 2mths work a year
Post #1066565 28th Apr 2025 9:10pm
JOW240725
I use Stihl SG31 & SG51, not perfect (pipe kinks) but had years and work well
https://www.stihl.co.uk/en/c/mistblowers-s...3AManually James
Instagram @suffolk_rovers
Post #1066693 30th Apr 2025 12:49pm
