Home > General & Technical (L663) > Rear hinges
lightning
Rear hinges
Has anyone had success oiling the back door hinges. I am sure the creaking/cracking noises are coming from the door hinges, but l can't see how to get to them.
lt was exactly the same noise as my old Defender made and oiling the hinges shut it up for months.
Post #1065151 9th Apr 2025 7:19pm
lightning
Nobody done it?
Post #1065213 10th Apr 2025 10:54am
Down & Dirty
Not done it but interesting as I have a creak at the back so will investigate and let you know if I come up with anything Thumbs Up 24MY HSE X-Dynamic 90 Carpathian Grey
Post #1065223 10th Apr 2025 12:38pm
Crazymind
I am not sure why cars nowadays have no hinges lubricated. I have spread lithium grease from day one on my defender. Some of my more techy friends with engineering background suggest is not needed. However it is harmless to spread some old fashion grease…and makes me feel better Smile
You can also use dry silicon spray if you feel rich…
Post #1065272 11th Apr 2025 8:44am
lightning
l've managed to oil the hinges with spray grease.
However it didn't stop the creaking.
Post #1065274 11th Apr 2025 9:10am
sasa
Czech Republic
please try lubricating the sealing rubbers, I also had a squeaking sound from the rear and it helped me
Post #1065278 11th Apr 2025 11:31am
sasa
Czech Republic
the sound is when you are closing/opening doors?
Post #1065439 14th Apr 2025 6:58am
lightning
No it's when l drive slowly over uneven ground.
Post #1065443 14th Apr 2025 8:33am
Nuclear Nick
Ditto Sasa's post, I routinely dress all the door seals with Gummi Pflege silicone lubricant. It seems to keep the creaks at bay. 23.5MY 90 V8 Carpathian grey
Post #1065465 14th Apr 2025 12:49pm
lightning
UPDATE
lt was the under trays that were creaking.
l removed them, sprayed grease on all the mounting points and bolts, and refitted everything. Now the vehicle is silent.
Post #1066073 22nd Apr 2025 6:04pm
Nuclear Nick
Ok, well done for that. Useful information for the future too, thanks. 23.5MY 90 V8 Carpathian grey
Post #1066094 22nd Apr 2025 9:41pm
ruben
Spain
lightning wrote:
UPDATE
I'm very glad, but can you be more specific about which under trays you're referring to? ...Are you referring to the underbody protectors? If so, did they transmit creaking noises to the interior of the car?!! thanks! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1066097 22nd Apr 2025 10:33pm
