![]() | Home > Technical > Rear Half Shafts Removed |
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 99 ![]() ![]() |
🤔diff lock? 24MY HSE X-Dynamic 90 Carpathian Grey
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6012 ![]() ![]() |
You either need to put your transfer box into lock, or as you have, put your handbrake on. Otherwise the centre differential is “open” so it will spin the easiest.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2308 ![]() ![]() ![]() |
As others have said - you need to lock your centre differential (diff lock) and you’ll be away.
It’s behaving correctly. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3626 ![]() ![]() ![]() |
With the handbrake on, without center diff you will get an extra high gear as the center diff will spin the front prop 2x normal speed
![]() Just dont do it for any long distance/speed. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Sybrow Member Since: 31 Dec 2023 Location: Skipton Posts: 46 ![]() ![]() ![]() |
Many thanks all. Appreciate the reply's
