![]() | Home > Maintenance & Modifications > HELP Defender 90 window going way too low |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 998 ![]() ![]() ![]() |
Hi
Have you compared the drivers side mechanism to the passenger side one? It could be that one of the stops has bent or is missing? Jim |
Soulrider911 Member Since: 04 Jul 2022 Location: California Posts: 119 ![]() ![]() ![]() |
Thanks Jim, where exactly is the stop? That is what I had assumed the problem is, but I don't know what I am looking for. 1989 Defender 90
2022 Defender 110 SE DIY’er | Always learning |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3638 ![]() ![]() ![]() |
IIRC, there is a tooth on the sector that is bent sideways, presumably to limit movement. But not sure. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21009 ![]() ![]() |
It may have jumped a couple of teeth down, that’s what I’d be wondering. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thank you to gain access to the limiter to i need to take the inner door panel off? Thank you 1989 Defender 90
I think if you wind the glass all the way up, you would see that part of the sector gear just below the inner panel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Thank you for the help, is this this area you are referring to:
![]() Click image to enlarge 1989 Defender 90 2022 Defender 110 SE DIY’er | Always learning |
That’d be it, it might have skipped some teeth, to sit a bit lower than it should.
Could be wear, and or when door slammed. Should be greased though, is it dry? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Yes thats the tab I refer to.
I normally grease mine. Not sure if its the right thing to do though as sometimes dirt and dust can act like grinding paste. Had gears become really pointy, but they still last me decent amount of years. A dry lubricant is probably more suited. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I just used lithium grease, I found when I last had a look they were completely dry, mind you like the wiper wheel boxes, they need doing I’d say very rarely, so I’d say about the same rate as wiper wheel box replacement.
I suppose that’d be about 6 to 10 years ish ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
