![]() | Home > Maintenance & Modifications > Removing text from hard rear wheel cover? Stickers/branding? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
How old is the cover?
I did the same in what was an 8 year old cover. I sanded the text with 1500 grit wet sand paper and then polished it. But the problem is that behind the text was protected from UV and remained a darker shade of black. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Helstoon Member Since: 08 Mar 2012 Location: West Cornwall Posts: 33 ![]() ![]() ![]() |
Gentle warming with a hairdryer wil soften the glue and enable you to remove them, then a clean with wd40 to remove any glue residue
