Home > Wheels & Tyres (L663) > 110 P400 20" or 22" Rims
fatphoca
I am about to get my first New Defender. It's a new to me P400 that comes with the standard 20" wheels. Nothing wrong with them but nothing that jumps out at me either.
I turned down a P300 because it had no air suspension. Will I be doing myself a disservice by going to 22" even if I have air suspension?
Currently looking at the Forza Octa style 22"wheels.
Thanks!
Post #1064302 31st Mar 2025 1:42pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
All depends on what you intend to use the car for - if going off road then the 20” will be better and even on road give a very compliant ride but the 22” wheels are not so good off road and make the ride a little harsher imho Thumbs Up Gas, Grass Or Ass - Nobody Rides For Free
"UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #1064318 31st Mar 2025 4:31pm
nigethecat
I'd stick with 20's as well if it were my car... I've just removed a set of 22's off a Disco 5 I bought to replace my Defender, and stuck a spare set of 20s from the Defender on the D5 with GG AT3s...
But having said that I run 22s on my RR Velar SVA but very different car to either of the others Very Happy
Post #1064327 31st Mar 2025 6:26pm
Boutrosa0517
United States
depends also on the quality of roads. I find the suspension reacts differently on the 22s. If feels more solid, truck like, but not harsh unless you put alot of air. if you have very bumpy roads, the 20s are a better choice to soak up bumps.
you dont want to run the 22s with comfort pressure/ light load either.
When I run my 22's ar around 42 front 45 rear, I find that the sweet spot for the type of roads in my area.
Post #1064368 1st Apr 2025 6:06am
fatphoca
Thanks for all the comments.
Roads are not that good round my way. This will be on road use only. I have a wrangler for the heavy stuff! (at least that is my intent).
For 20" what is the largest knobbly tyre I can go with? I'm thinking Nito Grapplers or something similar.
Thanks.
Post #1064392 1st Apr 2025 9:10am
Boutrosa0517
United States
I have both 20s and 22s. For on road even bumpy, I prefer the 22s. the 20s feel a bet unsettled. The secret for me is to keep the front tires between 42 and 44 psi and the rears between 44 and 47 psi. Makes a world of a difference.
for the 22s, they feel unsettled for me. handling not as good. the 22s ride better in my opinion. Now for offroad, you don't want the 22s.
Post #1066745 1st May 2025 2:35am
A1C6
Australia
In my opinion it drives better with 20” wheels than 22”, even if you aren’t going offroad. Ride is smoother, somewhat more direct driving experience.
Post #1066758 1st May 2025 10:45am
fatphoca
Thanks.
That's pretty high psi? When i picked mine up the tyres were at 40psi which made the ride too harsh imo. I lowered it to 34 at the front and 38 at the back and the ride was much better. These were the recommended pressures according to the door sticker.
Post #1067690 14th May 2025 1:46pm
