Home > Td5 > defender TD5 90 10p 2000
Dover mike
England 2000 Defender 90 Td5 CSW Arrow Red
good morning all hope you are all well i have a question i need to replace the fuel pump and sender unit will all defender TD5 fuel pumps fit as bear bones have Lucas WFX000250 one for sale @ £ 120
Post #1063836 25th Mar 2025 12:57pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
I replaced an in tank fuel pump on a TD5 a few years ago. The best price back then was offered by Maltings who will provide a further discount if you join their mailing list.
From what I remember the TD5 fuel tank is a different shape to the one fitted in the TD5 Discovery and therefore the level float assembly is different. I remember finding cheap fuel pumps but they were for Disco's.
I would only fit a VDO, Lucas or (if you can find one) Bearmach fuel pump as the cheap Chinese ones don't appear to last that long.
There is a great write up on the forum on fitting a circular marine waterproof hatch to change the tank fuel pump. I went down this route as it looks really professional as is what really should have been factory fitted for ease of access to to pump.
https://www.ebay.co.uk/itm/275341558658?fi...R7aivdq5ZQ
Jim
Post #1063842 25th Mar 2025 3:11pm
Dover mike
hi mate thanks when i fitted the galvanised chassis i done an ally cut out in the floor the one i found was for a defender Whats VDO ??
Post #1063844 25th Mar 2025 3:18pm
jim4244
Hi
VDO is the pumps that your Landy would have been fitted with at the factory, but branded Land Rover. They are £250+ but sometimes you can find them on special offer.
Lucas is a good pump and as you have a hatch cut already you can always easily change in the future.
Below is the link I used for my hatch:
https://www.defender2.net/forum/topic71836...pump+hatch
Jim
Post #1063847 25th Mar 2025 3:29pm
htb2
Wales
Disco ones fit just swap the float arm assembly over, that's what's in mine.
Post #1063886 25th Mar 2025 8:35pm
