![]() | Home > Maintenance & Modifications > Door Security. |
Just an idea I have been toying with....Opinions welcome!
I have just replaced the door hinges on my 90 and was surprised how easy it was to remove the fittings. I have never to date had to disturb the fittings in three years of ownership. Now fitted I was considering filling the heads on the hinges with a suitable resin or hard sealant. Whilst this would not prevent the most determined individual it would make access to an opportune thief a damn site harder. What d'you reckon? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Bobble Member Since: 21 Aug 2011 Location: Hampshire Posts: 223 ![]() ![]() |
And if you ever need to get the doors off?
If and when they do ever have to come off, patience, a toffee hammer and a couple of watchmakers screwdrivers would be my weapons of choice. Point is if need be I would still be able to get the doors off 'eventually.' A toe rag with tools could do it in 3-4 minutes at present. I think I may have just persuaded myself to do it anyway. Thanks Bobble. ![]() Treat every day as if it is your last....one day you will be right!! |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
Hi mal,
we used to get anti tamper bolts specified when we assembled toilet cubicles for secondary schools; you need a special tool to install/remove. Can't remember whether the threads would be compatible with land rover captive nuts, though? |
what about this?
http://www.made-in-china.com/showroom/trac...Screw.html |
Farmer,
We use them at work and if you have just the right size flat screwdriver the centre pin acts as a leverage point so you can still get then undone! ![]() Treat every day as if it is your last....one day you will be right!! |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
BPMan has some good security fasteners on his
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18027 ![]() ![]() ![]() |
Besides "security torx" bits are now so widely available that the concept is useless for secuity! |
paullo Member Since: 14 Dec 2010 Location: Just Outside the M25 Posts: 47 ![]() ![]() |
Ball bearings and crazy glue. I use them on my commuter bike so I don't have to worry about the seat, handlebars, etc.; not permanent, but will certainly deter the average thief with a set of screwdrivers. With a little patience and some of the mrs. nail polish remover you can undo everything.
drewster Member Since: 13 Jun 2011 Location: south coast brockenhurst Posts: 226 ![]() ![]() ![]() |
mal this was going to be my sugestion i will look further into it for you i think you can get the pin type infact i know you can as i used them on my zx9 when i dig into my garage i will let you know drew |
I really wouldn't bother with the torx/pin type security screws myself, since all the world and his dog now has the necessary security torx bits needed to unscrew them - they are sold everywhere. I suspect that if you rely on these to stop your doors getting nicked you are giving yourself a false sense of security.
I like the ball-bearing and glue idea, since that would be undrillable. |
