Home > In Car Electronics > 2001 Td5 radio upgrade
donmacn
Hi folks,
I have searched, and looked through a lot of “Td5 radio” threads, so am a little better informed but have just a few questions. Looking at upgrading the radio in friend’s car and I know zip about Td5s!
Hers is a 2001 car, with the factory cassette radio and dash. I found a thread on here which suggested pre-2002 vehicles should have DIN connectors - but no such luck. It’s the round pin plug in this car.
I’ll be fitting a modern, single DIN, mechless unit.
So, questions:
There’s no DIN mounting cage. Assuming one will come with the new radio (usually do) will this fit OK into the standard Td5 dash insert?
Will it wobble like Censored and fall out, or will it stay in place? I’ve seen that Raptor do a centre dash cover panel. Seems like a reasonable £50-odd to me, but not sure if budget would be an issue here. My plan is to fit the radio as best I can to the standard dash ‘as is’ and see how that goes for a few months. If there are no issues, that’s the way it’ll stay.
Are the wiring loom adaptors OK? I think I might have a set of ‘crimp on’ ISO plug somewhere, but the loom wires aren’t very long, so maybe a little awkward to crimp on new pins without taking the whole dash out. Using the adaptor would be a bit easier.
Her car just has the two front speakers in the lower dash. Will there be wiring somewhere for rear speakers? It’s not part of the current job, just curious if it’s an easy future option?
That’s it really - but any advice on this with the Td5 dash/loom would be appreciated.
Ta v much. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1062459 9th Mar 2025 4:56pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Hi, new radios come with their own cages, they are 'DIN' size so all fit in the standard sized hole. If you are making new connections you could do worse than fitting the vehicle side ISO connectors for speakers and power supply because they will mate directly to the radio loom that comes with the unit.
https://www.ebay.co.uk/itm/142427857851
There is a specific pin configuration, plenty of sources online to tell you how to do this.
There won't be any wiring for rear speakers if rear speakers are not already installed. The easiest way to add this is to go up the A pillar and behind the headliner, assuming there is one?
There are options for rear speaker pods online, MudStuff do some. Just to manage expectations...without spending mega bucks the audio quality in a Defender is pants! Rather than rear speakers consider a single powered subwoofer, such as a Kenwood KSC SW-11, a really good upgrade, easy to fit, doesn't cost the earth.
Post #1062614 11th Mar 2025 3:36pm
donmacn
Hi Penfold,
Thanks for replying.
My own car was a base/utility spec and had no radio at all, so I've had to do all of that from scratch. (Subwoofer AND rear speakers, and even fitted the wee tweety ones to the top of the dash - though I don't know if I'm getting any useful benefit from them!)
I had hoped that by the time LR got to 2001 they might have added just a wee bit of extra wiring to the loom, especially as they were fitting a radio from the factory. I've just had a closer look at the pictures I took of the wiring plug in my friend's car though, and I think you're right. There aren't enough 'pins' in the plug to allow for power x 2, earth, and eight speaker wires.
I could certainly run cables to rear speakers, but as I'm sure you know, doing it properly/neatly would mean getting the outer dash out to run the cables through to the audio unit. I've done that so often on my car I have no great enthusiasm to do it here, at least at this stage. Will take the 'quick and easy' route and see how that goes. Donald
in the past..
Post #1062620 11th Mar 2025 3:57pm
Penfold_6290
Hi Donald, I've done a lot of audio upgrades in my 110 (2002, facelift dash) and have never removed the outer dash, I just remove the top bar (with the air vents in it) and run my cables behind. That includes some fairly chunky RCA cables from the head unit to the sub in the back. I have seen somewhere someone makes a pod that mimics the facelift radio enclosure for pre 2002 vehicles, but you will have lots of switch blanks unless you intend to upgrade all the switches too.
By upgrading the vehicle side plugs you can also incorporate a the illumination feed as well if the head unit has a dimming function. Also the blue 'amp sense' feed if you intend to go that way. I like to have it tidy on the vehicle side, avoid Scotch Locks and any other nasty connectors. Might be a bit more work and a bit of a fiddle but good for peace of mind...we don't want any fires.
EDIT - This looks like a good option
https://www.mudstuff.co.uk/products/mud-de...&_ss=r
Post #1062622 11th Mar 2025 4:04pm
donmacn
Who mentioned Scotchlocks!! Whistle Very Happy
Proud to say I've never, ever used those!
With you 100% about keeping it neat. When I fitted a Raptor centre console to my car, I relocated the fuel gauge, hazard sw, clock and rear wash/w switches. I made up short extension looms/multiplugs and even went to the extent of ordering up wires in the correct original colours.... maybe not so much for my benefit, but for anyone who might come afterwards.
If the Td5-era vehicles still had the little tray that sits on top of the heater duct, with the 'cable duct' at the back, that's how I've chosen to run cabling before, and that's why I've taken at least part of the dash out to give access.
As I say though, that's more or less behind my questions, not being familiar with anything younger than 1998! Donald
in the past..
Post #1062623 11th Mar 2025 4:32pm
Mo Murphy
Might be worth a look to see if the speaker wires are already there. They were on mine.
50 Shades of Pennine Grey
Post #1062633 11th Mar 2025 6:08pm
