![]() | Home > Puma (Tdci) > Fuel Leak Off Pipe connector popping off |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1029 ![]() ![]() ![]() |
For £100 I’d buy a genuine leak off pipe to replace your current one and hopefully that will sort the problem.
The leak off pipe is a replacement item if you have had the injectors out in the past. Connector could be worn as it’s just plastic. 2017 L494 Range Rover Sport SVR 2008 2.4 110 Utility Station Wagon XS. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 818 ![]() ![]() |
I'd check the other pipes to confirm this is the case , but I'm pretty certain the leak off pipes are retained by a metal clip..
Is yours present? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
Some are.retained by metal clips, most are retained by plastic clips which break easily. The clips are widely available e.g. from Ford, eBay, etc.
RACH-OB Member Since: 07 Dec 2024 Location: Geelong Posts: 10 ![]() ![]() ![]() |
Hi thanks for replies I have tried to attach a photo of the leak off connectors, hopefully it uploads. They are definitely plastic, no metal clip.
I also had purchased a genuine replacement leak off pipe several weeks ago but as the problem hadn't reappeared I did not install replace the current one. Why would there be such a large amount of diesel coming out of the pipe? |
Cheers mate, interestingly the injectors were replaced by previous owner around 6 months ago. |
![]() Click image to enlarge
So where exactly is your leak off pipe blowing off from..
The leak off fitting ...ie the black plastic bit with is retained in the injector by a metal clip..it's visible in the photos.. And possibly the best way to check this is to do a leak off test on all four injectors...I dont know the quantities at say tick over , but they should all be about the same..if not you have likely got a faulty injector.. |
Thanks for the reply mate @andy63. Yeah the female green connector is disconnecting from the male piece attached to the injector.
