Home > Puma (Tdci) > Towing Electrics & Leisure Battery Charging
m7ble
United Kingdom 2009 Defender 110 Puma 2.4 USW Corris Grey
Evening,
It's probably a straightforward answer, but I struggle to understand this.
I have two 7-pin connectors (image attached). I believe the one don't the right is N, and the white one being S on the left.
I'm building an overland trailer and would like to charge the leisure battery while driving. The wiring kits I've seen for the build always have a chunky, thick cable going back to the alternator, as they are designed for van conversions.
Why can't I use the S connector to change the leisure battery while driving? Is it worth updating it to a 13-pin? Is there an easy way to merge the two, maybe plug and play?
Post #1059431 3rd Feb 2025 10:08pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
My understanding is that you could, but only a small number of amps can flow down the weedy wire. I have big fat cables going to an anderson connector, but that charges 2 x 12v batteries that could be completely flat after a few days, so need more amps.
Post #1059436 3rd Feb 2025 10:19pm
m7ble
Weedy wire Rolling with laughter
That’s exactly what I was thinking, why is it so thin as it kinda makes it redundant but it was probably sufficient 10 years ago.
This is the last part of the puzzle I need to solve. I’m trying to make the overland trailer future proof and even maybe tow it with the wife’s car so I need to come up with a solution.
The trailer will have a 240v hookup and also solar, I’ll get about 5 days off the leisure battery which will probably be enough, and if we moved campsites it would get a top up whilst being towed.
Post #1059440 3rd Feb 2025 11:01pm
macfrank
I also thought the "S" was introduced to do just that and the 13pin was just a more convenient merge into one plug. There are separate ground wires that match the respective 12V wires to take care of the amps, but I wouldn't use them for more than 10A each.
Post #1059442 3rd Feb 2025 11:09pm
