![]() | Home > Technical > Defender 90 v8 starting issue |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
Check Relays work correctly
samuel_brulhart Member Since: 26 Jan 2025 Location: New Territories Posts: 2 ![]() ![]() |
Thanks for the reply.
Yeah agree the relay might be the issue, will check the relays and also try a cable from the ignition switch to the ignition coil and see if it works. Will post an update after that |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Are the earth points on the transfer box and near the top of the bell housing good? 2002 90 Td5 Station Wagon
