Home > In Car Electronics > GLOHH lighting system for Defenders
Page 2 of 3 <123>
TrvMac74
United States
Does anyone know what headlights the white defender on the Glohh adds?
Post #1063099 17th Mar 2025 1:17am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
if you email there support email, they maybe willing to tell you, I think the car is from Iceland Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1063102 17th Mar 2025 8:43am
TrvMac74
United States
I did that last week and they wouldn’t tell me due to liabilities seems odd
Post #1063135 17th Mar 2025 3:03pm
Biscuits
United Kingdom 2001 Defender 90 Td5 CSW Epsom Green
They look identicle to the ones on my car. Nothing special I don't think. No branding on mine, so probably cheapo ones 2001 90 TD5 Soft Top - Epsom Green
2024 90 D300 HSE X-Dyn HT - Santorini Black
Post #1063138 17th Mar 2025 3:23pm
TrvMac74
United States
They were very dark/smoked that’s what I’m looking for. I’m in the US so tough to find anything local for these Defenders
Post #1063153 17th Mar 2025 5:17pm
TexasRover
Aren't they just standard 7in like fitted to beeps?
Post #1063155 17th Mar 2025 5:33pm
TrvMac74
United States
Yes they do but as mentioned just curious what these might be as haven’t seen them in The US
Post #1063166 17th Mar 2025 6:27pm
Shirty Carpet
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
For those that have fitted the fronts, how did you do it?
For the offside, on my 2015 MY XS, I can just about reach through the wing top cover but that doesn’t seem to be an option on the near side because of the heater ductwork.
I did try removing the headlight but there’s no way I could see that I’d be able to re-fit it with the headlight surround in place.
The wheel-arch liner doesn’t look to have any give in it to allow me to loosen a few fixings and get my hand inside there.
A search elsewhere suggests the wing has to come off to remove the liner - seems a little drastic for what I’d hoped to be a simple job.
Am I missing something obvious here?
Post #1065159 9th Apr 2025 8:21pm
grafty99
You need to remove the wheel arch spat to access the gap between in inner and outer wing Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #1065333 12th Apr 2025 8:52am
mmddbb
2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
In case it is of interest to fit the fronts I 3D printed in ABS some plugs to replace the existing light/body plugs. These screw on to the threads of the Glohh lights and then push in to the body, which makes fitting a 30 min job as opposed to a couple of days if you have to remove arches and fiddle about in the wheel arch. Easy to fit, easy to remove and should work with standard light surrounds.
Post #1065346 12th Apr 2025 12:43pm
Shirty Carpet
That sounds very interesting. I’ve no access to a 3D printer but if this is something you’d be prepared to print for me then please DM me and let me know cost etc.
Post #1065399 13th Apr 2025 11:56am
mmddbb
Of course, PM sent
Post #1065404 13th Apr 2025 1:22pm
Shirty Carpet
A huge thank you to Matt (mmddbb), the fittings that he printed made it super easy to fit the Glohh front lights. You can see from his photos above that being able to pre-assemble the lights into the headlight surround is very straightforward. Then it was simply a case of lining them up and pushing them home. They seem really secure and so much less daunting than having to gain access through the wheel arches.
Drop him a message if you’re about to fit these too - I’m sure he’d help out anyone else interested in them.
Post #1066405 26th Apr 2025 7:24pm
Lalathan
United Kingdom 1992 Defender 90 BMW M57 3.0 Diesel CSW Auto Arles Blue
Could you message me or email me mark@lalathan.com
I would love to buy these... no 3d printer here either
Post #1068017 18th May 2025 1:37pm
Werner Scharlau
Spain 2008 Defender 110 Puma 2.2 SW Zambezi Silver
Technical Inspection problem in Spain
Correct numbers on front blinkers GL 2 missing. After discussions with Glohh the sold me blinkers with correct numbers, having to pay again for them. After many discussions and disconnecting the fog lights and adding a separate fog light the Technical Inspection Authority in Spain is ready to accept these tail lights. However one of the lights is not working correctly and GLOHH ignores my mails to replace it. GLOHH mentions that lights have passed ECE guidelines, which is not true. Only 3 brake lights are allowed (tail light of Glohh are already 4 lights) and fog light must be 10 cm separate from brake lights which is also not the case.
Post #1072476 30th Jul 2025 10:13am
Page 2 of 3 <123>
