Home > For Sale & Wanted > [For Sale] Defender swivel oil seal & pin kit
TC909
New never used parts needed to change the swivel pins & seals on a Defender 2008 onwards with ABS.
Only missing the drive member gaskets I think. All cost around £170 but not needed.
Collection from Lincolnshire or can post for cost.
£90.
Oil seal : FTC3401 x2
Swivel pin x2
FTC 3647 Gasket
Hub grease x2
FTC4785 seal x2
Hub nut x2
Pads set of 4
Kit swivel pin TAR100050 x2
Hub bearing outer RTC3426R x4
Spring kit x1
Brake pad fitting kit x1
Bearing taper 606666 x2
Post #1056684 8th Jan 2025 3:41pm
