Home > Maintenance & Modifications > should i upgrade headlamps
Page 2 of 5 <12345>
robpenrose
Keeping your lights clean will really help get the best output. Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #103717 1st Dec 2011 12:51am
ZeDefender
I recently fitted the Osram Nightbreakers and Crystal headlamps from Paddocks in my Puma - really big improvement on dip, nothing special on full beam... but I use dip most of the time anyway Thumbs Up
Can't tell whether the bulbs or lights are responsible but I could only be arsed to change them both together Whistle Tell someone you love them today because life is short.
Post #103718 1st Dec 2011 12:59am
I fitted some wipac crystals and a pair of PIAA brilliance bulbs - seem to be fine - one day I'll get some 8700s but waiting to see what happens legally and if 8700 are going to be updated Thumbs Up
Post #103736 1st Dec 2011 8:44am
Naks
Best bang for buck is Wipac crystals + some uprated bulbs --
Post #103748 1st Dec 2011 10:27am
T1G UP
do the headlights etc have to come out to change bulbs?
Post #103751 1st Dec 2011 11:12am
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
lights
http://www.osram.com/osram_com/Consumer/Au...index.html
what is the best price you have seen for these?
Post #103754 1st Dec 2011 11:31am
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Yep , 10 min job tho. I fitted the Phillips extreme bulbs and they were a marked improvement that I didn't bother with the lamps (11 plate Def 90)
Stu
Post #103755 1st Dec 2011 11:35am
paullo
Canada
http://www.landyzone.co.uk/lz/f41/headlight-renewal-130728.html
It even has the requisite photos to help! I used this as a guide the other week when I swapped out the OEM lights for Crystals. Worked a treat and took about 10 minutes for the first side; and even less on the 2nd light.
Post #103786 1st Dec 2011 4:07pm
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
the better option is to fit a set of spots to an a bar
Post #103791 1st Dec 2011 4:27pm
MartinK
Buster does a good set of write-ups on Landyzone - I followed them last time I changed the track and steering rod bearings on my Discovery...
We could do with more like that on defender2...I did write-up the oil change process (sticky on the TDCi page) for thaty reason...we could get a good library going between us! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #103793 1st Dec 2011 4:37pm
T1G UP
great idea Martin...also the FAQ's about engines, suspension wheels tyres, etc etc etc could be thinned out and made sticky or a tech archive
Post #103795 1st Dec 2011 4:53pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Ive got those Wipac crystals as part of my SVX front conversion, and the difference in light output over the standard lights is incredible. The improvement on dipped beam is worth the money alone. Id recommend crystals to anyone.
Pete
Post #103938 2nd Dec 2011 12:05am
scottish110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Pete
CHeers for the advice mate Thumbs Up
Post #104010 2nd Dec 2011 11:48am
richuk
Just fitted my Crystals and Philips X-Treme. No problems fitting, but not quite as straight forward on the Puma due to the added complication of the electric leveling motor. Could not see any way of removing the old lens without disturbing the headlamp aim screws, now have two horizontally opposite each other and a third on the electric drive. Just waiting for darkness to see how much difference there is to the standard set up. Rich
semper in excretia sumus solim profundum variat
Post #104056 2nd Dec 2011 2:45pm
ZeDefender
There's another thread I was in about adjusting them the old-fashioned way until you can get it done by a machine. I did mine myself and the local TÜV garage said they were fine! Tell someone you love them today because life is short.
Post #104060 2nd Dec 2011 3:41pm
Page 2 of 5 <12345>
