Home > Td5 > Td5 gauges back lights not working
Mr110td5
Hi all,
I attempted change my Speedo lights today as they were gone - absolute nightmare of a job, managed to change 1 however, as it got a bit dark thought I'd attempt the other one tomorrow
As I packed up for the day, I did a quick test flipped the main lights on & unfortunately none of my guage lights are now working? Speedo / fuel/ temp / time - none of the back lights seem to work
I have also lost one side light as well as both of my spot lights connected to my bull bar.
Could anyone point me in the right direction please?
Literally all the back lights worked as I was trying to put new bulbs in the Speedo and now gone & well as the spot lights & one side light gone Sad
Headlights work fine.... Please help!
Post #1055058 18th Dec 2024 9:56pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
The first job is to check your fuses. Fuse 15 protects the headlamp relay and instrument lights. Power to your instrument lights will be on a white wire with green tracer, check you have power to the plug that connects to the instrument cluster, if not work back from there.
Post #1055097 19th Dec 2024 12:19pm
