Home > Puma (Tdci) > Puma ignition barrel
roche1800
Does anyone know if you can have the existing ignition barrel repaired to match existing keys or buy a new ignition barrel to suit existing key please.
Post #1054940 17th Dec 2024 1:56pm
Naks
AFAIK, you have to replace the whole barrel and then you get new keys with it.
At least that's what happened when they replaced the barrel in my Puma. --
Post #1054942 17th Dec 2024 2:29pm
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
As Naks say. You get a kit with the ignition lock, keys and two barrels for the doors. I have one waiting for me to get around. It is the shear screws that is my headache, and since I don't HAVE to do it, I don't want to start something that turns into a weekend of work.
Post #1054946 17th Dec 2024 3:06pm
Ianh
Just double checking. Are you replacing the ignition barrel because the barrel is worn and not working correctly, or because the electrical switch element is not working. Just checking as you can get the switch part separately.
On the barrel front, worth giving a dealer a call to see if they can match a new barrel with your key number. Noting you will need a key number but they “should “ be able to find that from your vin if you don’t have the key number.
If you do have to get a new barrel with new key I think a kit that includes side and rear door lock barrel replacements is only a little more than just the ignition barrel. That way you can change all. A pain but leaves you with needing just one key.
Post #1054947 17th Dec 2024 3:08pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Some/all Pumas have different length door barrels to what is commonly available.
Post #1054959 17th Dec 2024 5:31pm
