Home > Technical > Electrical extras |
mymini007 Member Since: 10 Nov 2011 Location: Chippenham Posts: 273 |
I have read that adding a 2nd 12v power socket is as easy as piggy backing the existing one,
how many times can this be done? I also want to add some extra lights, and a fan heater and some other bits and bobs, whats the best way to do all of this, I will end up with about 5 feeds off the battery, or should I add a new fuse box and wire all the new bits from there? |
30th Nov 2011 10:01am |
Thats great thanks. Will have a go this weekend if I get time. :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
30th Nov 2011 1:14pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
Hi MM
In my opinion, the best thing to do is what Brendan suggests, add an extra fuse box and run your extras from there. I have fitted the box that Brendan posted a picture of in my battery compartment and then run all my extra circuits from there. The only extras that go directly to the battery are the winch and the CB but I am probably going to move the CB + ve to the extra fuse box over Xmas when I have some time. Only tricky bit about the whole operation is getting the correct cables to run from the battery to the new box but I am sure somebody like Brendan could help with finding them or he may even supply them. I fitted my extra fuse box quite some time back but I think the total cost was in the region of £45 pounds for the box plus the cables to hook it up to the battery. With the amount of time it has saved me when fitting new circuits and the peace of mind that everything is wired and fused correctly it has more than paid for itself Have a read of this thread to see how the job is done. http://www.defender2.net/forum/topic1331.h...a+fuse+box Bob |
30th Nov 2011 5:34pm |
I just took the original fuse box cover off to wire up a stereo What a mess, managed to wire up the stereo from the old wires, but in the box there are wires everywhere. So the new fuse box will be the way to go, I will cover the old one back up and, hopefully not have to look in there again |
30th Nov 2011 6:08pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
We sell that 12 gang fuse box for £31. If you need help with the main cables give me a shout and I will try and help you out.
Brendan |
30th Nov 2011 9:19pm |
Thats great cheers You cant polish a turd! But you can roll it in glitter 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
30th Nov 2011 10:57pm |
