Home > Td5 > Td5 sound
Betsy
 1999 Defender 110 Td5 HT Coniston Green
Td5 sound
Good evening all
I’m always hearing people say how amazing the td5 sounds, mine doesn’t!🤣
On tick over it sounds ok but when revved it sounds very much like a early defender engine, also when accelerating it’s very load in the cab
Any ideas to give it a better less tractor like tone, even my 300tdi with a centre box delete was quieter and had a deep burble
Thanks
Post #1051504 12th Nov 2024 9:56pm
landy andy
What exhaust and what parts do you have fitted?
Post #1051507 12th Nov 2024 10:00pm
Betsy
As far as I’m aware it’s all standard
Post #1051509 12th Nov 2024 10:03pm
Betsy
It’s a 1999 so has no cat, I’m tempted to put a centre delete pipe in
Post #1051518 12th Nov 2024 10:47pm
Jabberwocky
Luxembourg
3inch down pipe and no silencers should do the trick, certainly does on mine.
Post #1051519 12th Nov 2024 10:50pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
TD5 with no centre silencer is a reasonable compromise.
Not too loud, but has a slightly more satisfying low down grumble.
Weirdly, ours used to drone something rotten in the cab when the centre silencer was fitted- it's possibly slightly noisier now but is a less unpleasant frequency/sound somehow.
Chris
Post #1051522 12th Nov 2024 11:01pm
Betsy
That’s interesting Chris, thanks, that’s kind of what I’m thinking
Post #1051528 12th Nov 2024 11:12pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
The best ones I’ve heard on You Tube were made by Demand Engineering. I’ve used Longlife custom exhausts on several vehicles and have been very pleased with the outcome. I think a larger diameter pipe changes the note on diesels quite a bit, makes it deeper. 1983 110 automatic OM606
Post #1051555 13th Nov 2024 9:02am
Betsy
The demand ones do sound good, I think you might be right about going to a larger diameter, iv heard that before, In fact some say it actually makes to car quieter
Post #1051863 15th Nov 2024 8:14pm
