Home > Puma (Tdci) > Revs drop with stationary throttle
Page 2 of 2 <12
That does sound like VCV if there are no DTCs suggesting otherwise.
Post #1051238 10th Nov 2024 3:13pm
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
I’m getting the codes read tmw, not sure what diagnostic brand they will be using though. I’ll swap the vcv anyway cheers
Post #1051240 10th Nov 2024 3:15pm
andy63
Are you able to look at rail pressure and boost pressure while it's doing this..
It does sound like it's over fuelling..
Does the vcv valve default to open and when powered it limits fuel..or the other way round.. I always thought it defaulted open, but I've been looking at one recently off a ford connect i think it was..it appears to need power to open..
Stuck open would give you high rail pressure at low demand i suspect and give you the symptoms you are describing..
Post #1051241 10th Nov 2024 3:32pm
Phillywilly72
I’ll try and get those readings read at the same time thanks
Post #1051244 10th Nov 2024 4:10pm
Try checking the Turbo actuator too, light lube the pivots in case of sticking.
If the VCV is sticking, it might be slightly over fuelling, and more likely if revving it which isn’t ideal from cold anyway too much, but it tends to under fuel more.
Good luck tomorrow, but as mentioned no DTC’s are produced from the VCV even if it’s in a dire state.
Blackwolf - Sounds about the sort of figure that LR would go for, I think you mentioned it before.
Perhaps the throttle works the way it does as a kind of safety measure, alongside the anti stall as well when that’s active. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1051253 10th Nov 2024 6:26pm
Phillywilly72
I’ll give an update when it’s been on a reader and swapped the vcv. Thanks
Post #1051254 10th Nov 2024 6:45pm
Phillywilly72
I ordered a Denso part but this turned up, anyone had any experience with this make?
Post #1051426 12th Nov 2024 2:56pm
Phillywilly72
Update- All back together and problem gone. SCV/VCV was the issue. Thanks all contributors
Post #1051900 16th Nov 2024 1:57pm
Page 2 of 2 <12
