![]() | Home > Puma (Tdci) > Heated Screens |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
This morning I had my first opportunity this winter to use both front and rear heated screens and there seems to be problems with both, rear top 2 elements not working, front has at least 3 verticals not working. Looks like it's a trip to the dealers for some warranty work, they can also look at my rear door not locking / unlocking with the central locking
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
There are previous posts about the rear screen on here, the conclusion being that the plastic cover around the stop light wears away the track of the top elements. Mine has done it as well and the dealers offered me a replacement rear screen without hesitation.
I don't know what the warranty situation is with the front screen, but having had a Disco II with the same heated front screen for some years now, the elements do eventually break as you are describing. |
When I had that they just replaced the front screen with no quibbles at all.
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
I had two replacement rear glass on my first Puma in two years and one in this one but like you turned it on this morning and that has goen too.
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
I think I had a wire go on my front screen, but am waiting for the frosts to come so I can check. I do feel a bit bad having to complain about the vehicle though...
So far as I know the back screen is fine. Just wish I could find out what the hell is rattling back there. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
DIY repair?
http://www.thescratchdoctor.co.uk/demister...edsafi9td2 ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I had that with the rear glass too and the rear hi-level brake light will eventually fail too. LR quoted me £400 to replace the glass and i called LRCS and they paid for a wire to be run to the brake light (out of warrenty). They know of this problem and just wait till the customer complains. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Edited for accuracy ![]() |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
Both my Pumas had / have a line that didn't clear down the centre of the windscreen - I thought this was just the way the screen is split into two elements. Anyone else have this? John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Mine has got steadily worse, 1 line then 2 now 3. |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Can't remember about my previous Puma but the front screen clears much quicker on the passenger side than it does the drivers and there is a bit of a gap that takes even longer to clear between the two. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Andreas Schuback Member Since: 25 Oct 2011 Location: scotland Posts: 31 ![]() ![]() ![]() |
heating elements on new rear screen runs round the outside of the brake light so it will not rub through the element, make sure you get this screen and you should be ok cheers.
heating elements on new rear screen run round the outside of the brake light so it will not rub through the element, make sure you get this screen and you should be ok cheers.
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Thats the flatbed trailer ![]() |
