Home > Maintenance & Modifications > 75/90 in the diffs ?
rossy
for the differentials the owners manual recommends 85/90 and many owners use 80/90. I just wondered if it was OK to use an EP 75/90 GL4/5 such as Castrol Syntrax (which also goes in the transfer box). The main reason I'm asking is that the pinion seal has a tendancy to leak and would the slightly thinner semi synth 75/90 tempt fate in this regard ?
Or maybe its best to use a good old fashioned mineral EP80/90? I don't know but its my next job on the truck and I'd appreciate any advice. Thanks
Post #102750 27th Nov 2011 10:45am
MK
75w-90 is fine in diffs. Puma 110" SW
Post #102775 27th Nov 2011 12:52pm
wslr
The Castrol EPX is what should be used in the Defender diffs. The Syntrax Longlife is used in the Defender T-Box, but is also used in the D3/RRS diffs in place of the SAF-X0 that was originally specified.
It's all about additives now. Rolling Eyes
Post #102789 27th Nov 2011 1:56pm
df1
So would I be mad to just put straight forward EP90 gear oil in Diffs and transfer box ?
Post #102798 27th Nov 2011 2:59pm
MK
It would not matter as long it is GL-5 (for diffs). GL-4 is good enough for the Tbox. Puma 110" SW
Post #102806 27th Nov 2011 4:32pm
df1
Just checked the can, It's Carlube EP90 API GL-5.
So I guess I'm alright with that.
Just on the issue I find ATF gives smoother changes than MTF94 in my R380 box, doesn't seem to be any excess filings or anything at changes (do it every 12k miles), I presume it's not having an adverse effect on the box.
Post #102823 27th Nov 2011 6:21pm
rossy
thanks all for the advice. I guess syntrax is OK then which is good as I have rather a lot of it in the shed !
Post #102933 27th Nov 2011 10:59pm
