Home > General & Technical (L663) > USA Defender Configurator - P400 to P500
A1C6
Australia
I just noticed that for some reason, when you select the engine as 'P500' for 110's on the USA configuration it restricts the wheel selection. It's not because of the brake size, as you may be thinking, since it changes what specific 20" wheels are available.
See, with P400 selected these are the options:
While, this is what you can get with the P500 engine:
Why?
Post #1049299 21st Oct 2024 8:39am
Telemarkskier
At least you have the p500.Apart from the Octa the only petrol on the uk configurator is a 2.0l plug in hybrid 2020 Defender 110 SE 240D: Fuji White.
2011 Freelander 2 SD4 HSE
2007 Freelander2 HSE (man)
Post #1049330 21st Oct 2024 2:59pm
CincyRovers1
United States
Probably because they sometimes change things up for different trim levels. V8 engines are low-volume, too. Makes sense that they'd streamline options on low-volume trims. Plus, this style is the most popular on the Defender and also makes sense why it has always been the only option.
The V8 trim and the P500 SE have only ever been available with the Style 5098 wheels. If you option the 20" version, they automatically come with the Wrangler Adventure tires. The all-seasons are only available on the 22"
The 5094 and 6011 are both new for the 25MY with the V8; this is the first time anything else other than the 5098s have been available. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1049337 21st Oct 2024 3:41pm
