![]() | Home > Technical > Air Intakes |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 785 ![]() ![]() |
Well I've been commenting on the subject on and off and recently expressed my views on the alisport system I fitted after eventually finding the time to do and complete a few tests.., and whilst you will have a different engine and set up I'll make a couple general points you may want to consider..
You say get more air into your engine..my question would be more air than what..have you or do you monitor the intake air at present?? On the question of ducting..you need to try and establish whether your present set up is supplying your current engine needs (over its operating range) without been a restriction..again we are back to the point of needing to know what is actually flowing and maybe disconnecting it briefly from the air box to see if you get more air than with the ducting connected..if its adequate and doesn't affect the figures then there is little to be gained by increasing capacity unless you say intend say upgrading the turbo.... Those would be my first thoughts on the subject 👍 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8318 ![]() ![]() ![]() |
I can't currently.measure.air intake vol but I belive it needs more air! Cheers
Redlinemike Member Since: 27 Oct 2013 Location: Frozen north, Just off the M8 Posts: 100 ![]() ![]() ![]() |
I have recently went to a 4" snorkel which is 4" all the way to the airbox where it steps down to 3.5",
![]() Click image to enlarge 110 XS DC M57 + 8 Speed auto ORA jeep- Sold Tomcat 88 |
ok, so same engine. And???? any difference. before you had what 3.5 to that converted wing grill? Cheers
that noisy?
nice plate. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Induction noise isn't much different other than it sounds cooler, so far have found it to make a difference in regards to the general smoke under load , it's gotten better from a haze to a wisp is probably the best way to describe it when working it hard 110 XS DC M57 + 8 Speed auto
