Home > Maintenance & Modifications > D.C. Front prop
Evil Elsie
United Kingdom 2002 Defender 110 Td5 HT Alpine White
D.C. Front prop
Hello,
Double Cardon front propshafts - should the double Cardon joint be 'spring loaded' (that's probably a crap way of describing it)..?? Neither of the DC joints can be set to any position like a normal UJ. They're either hard over one way or the other - and you wouldn't want to get your fingers caught in there..!!
Hopefully that makes sense..??
Cheers, Dave 2002 Land Rover 110 Td5 Utility
1990 Suzuki GSXR 1100L
1980 Yamaha RD 350LC
1976 Yamaha RD 400C
Post #1045020 6th Sep 2024 2:00pm
Evil Elsie
Just been out for a mooch about and it looks like the flange at the DC end is too big for my diff. 🙄
The prop I've bought is a Disco 1 DC front prop.
I know that the D2 one wouldn't fit but looking at this one sold by Terrafirma I assumed that a D1 one would;
TFDC610 - Double cardan front propshaft for 90/110/D1 300tdi, Td5 & V8 610mm
Any thoughts..?? Should a D1 DC prop fit..?? If so then I've been mis-sold a supposed D1 one (apologies for the amount of 'ones' in this post)...🤪
1976 Yamaha RD 400C
Post #1045046 6th Sep 2024 6:51pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
As far as I know the flange should be the same at the diff end, but the dc end flange goes at the transfer box anyway. A disco 2 had a larger flange, don’t know about disco 1. The flange on the transfer box can be swapped out for a larger one, so long as it doesn’t catch anything else. The ends should sort of flop over, perhaps when the joints are new they have a slight spring effect?
Post #1045080 7th Sep 2024 9:35am
Evil Elsie
Thanks Mark.
There was going to be a follow-up question for anyone that answered - 'which end does the DC go..??' and you've answered that 👍👍
The prop I've bought was advertised as a D1 (new, never fitted but obviously stored in a damp garage for years 🙄) but I guess it must be a D2.
Not sure now whether to sell it on ( or put it in the spider-shed where unloved spares go) or see what's involved in swapping T/box flanges.
Typically, the previous owner fitted a D2 T/box, so the D2 flange will have been removed and a Defender one fitted..??
1976 Yamaha RD 400C
Post #1045087 7th Sep 2024 10:18am
MarkBrown
I’ve found the flanges interchangeable, just undo the big nut. Are the joints good on the one you’ve bought?
Post #1045108 7th Sep 2024 4:26pm
Evil Elsie
Thanks Mark - I appreciate the replies.. 👍👍
The prop has 'GKN' and some illegible numbers cast into the drive flange.
It also has '173313' and 'BV 56' stamped into the shaft with what looks like letter stamps. I can't find anything via Google.
I've measured the closed length and it's only 560mm and it could well have been shortened - it looks a bit 'rough' around the sliding joint. Could it have been shortened for a different engine/gearbox configuration..??
Any help/suggestions gratefully received.
What is it they say about a fool and his money..??😀 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1045134 7th Sep 2024 8:26pm
MarkBrown
GKN was an original supplier. The only difference in the flange is the diameter I think ( larger) as for the length according to eBay listing a new D2 DC front prop is 610mm. Mines a 300tdi chassis and the D2 front DC prop fits fine, I don’t know about the other models, it depends on where the transfer box sits in the chassis presumably. I think the pumas are different anyway. I’d measure what you’ve got and go from there.
Post #1045182 8th Sep 2024 10:41am
Evil Elsie
Hmmmm, the stock front prop is 610mm closed length.
The abomination that I've just bought is 560mm closed length.
Diff flange to Tbox flange measures 625mm (+/- a couple).
Not a chance this DC one is going to fit....😢
I'll send the seller a message - but it could be chucked into spider-shed and spend the next couple of years next to the Jackable sills (with tree bars) that I bought and don't fit....
Thanks for your help Mark.. 👍👍 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1045215 8th Sep 2024 1:58pm
