Home > Wheels & Tyres (L663) > Terrafirma 20” steel wheels
Thoughts?
Love them!
62%
 62%  [5]
Buy alloys!
37%
 37%  [3]
Total Votes: 8
jcthemaltesefalcon
Japan
I’m awaiting delivery of my D350 110 within the next 6weeks, and living in snow country I’ll be needing a second set of wheels with dedicated snow tyres.
I came across these proper steelies, about 5kg heavier each corner than equivalent alloys, but they’re solid, cheap and fit the Defender look:
https://terrafirma4x4.com/terrafirma-20x8-...f1520.html
Has anyone fitted or seen them fitted on an L663? Any issues I should be aware of before I bite the bullet?
I’ll be running these at least 4/5months of the year.
Thanks
Post #1044531 1st Sep 2024 11:48pm
Crazymind
They were on my list! Then I found super cheap brand new white wheels with tyres off gumtree.
I will get them powered coated black.
Check Tuff Torque as well. I think they are cheaper than Terrafirma.
Post #1044541 2nd Sep 2024 7:25am
jcthemaltesefalcon
Japan
Thanks!
That would be my first choice but 18’s won’t fit on the D350 due to brake calipers.
Post #1044550 2nd Sep 2024 9:22am
Mudlark
I have fitted these to my P400e but you may need spacers (as I did) if you have larger calipers.
I also fitted new Grabber tyres - same size but just scrape a touch on full lock on lower height setting. Presume a deeper tread pattern but I just lift the height if I need full lock when parking for instance.
Post #1055445 23rd Dec 2024 4:51pm
