Front door stays issues
Been reading through a few threads here about tightening up the bolts that hold the front door stays. This works well enough for the front passenger side door.
But on the front driver side door, the bolt nearest to the door seems to have stripped the threads off? It's turning very loosely. See pic for the bolt that I'm pointing at.
What is the bolt threading into? Captive nut? Is there an easy way to reach behind the driver side door stay to put a new nut on?
This is a Td5 Defender with ABS, so there's the ABS pump next to the brake booster. Saying this in case the nut that I'm after is right under this.
