Home > General & Technical (L663) > Automatic headlights
lightning
Does anyone know if any adjustments at all can be made to the automatic headlights using the GAP tool?
For instance, turn the automatic function off so they don't come on when l drive under a tree on an otherwise sunny day, and immediately turn off again having passed under said tree.
Then have the car in front stop to find out "why are you flashing your lights"
Or at least, adjust it so they don't come on when the light reduces for five seconds. For instance when driving under a tree.
lt must be legal, to be able to turn it off, as our 2020 Jimny has the option for completely manual headlights.
You can turn the headlights to "off" with the column stalk but they immediately turn back on when you start moving.
Post #1041522 31st Jul 2024 9:20pm
lightning
l guess not then. lt was worth posting just in case.
Post #1041685 2nd Aug 2024 3:47pm
Retroanaconda
I’ve never had them come on when driving under a tree - it would need to be a decent length of dark/shade for that to happen.
Post #1041686 2nd Aug 2024 3:50pm
BadgerWaz
Can't you turn off the auto/on setting in the pivi?
Also if the car in front stops because they think you've flashed your headlights I'd suggest extending your middle finger as you pass Laughing
Post #1041699 2nd Aug 2024 7:03pm
lightning
l don't know, can you turn it off? Won't it just turn itself back on like the stop/start
Post #1041717 2nd Aug 2024 8:55pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Didn't you post a very similar thread a while ago? Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1041720 2nd Aug 2024 9:46pm
BadgerWaz
Do you have a GAP 4?
If not I can sit and scan through the 1000+ list of codes and let you know. There are a lot of lighting options so at a guess I'd say you could turn auto high beam off permanently.
I'll be turning off the unnecessary brake assist, twice now the car has slammed on and swerved the steering as we've driven around bends with parked cars on them (at the roadside on the bends). Ridiculous.
Post #1041721 2nd Aug 2024 10:01pm
lightning
Same here, with me it was when l am waiting in the middle of the road to turn right, and a gap in the traffic appears.
l turn and the Defender decides there isn't enough space and slams on the brakes, nearly causing an accident
l've got the GAP 3 currently. Keep meaning to send it back in exchange for a version 4. I would happily turn off the automatic lights or at least make it an option like it is on our Suzuki Jimny.
Somewhere it will be possible to calibrate the sensor and one option would be to reduce the sensitivity so the lights only come on automatically when it's actually dark. As you already have the DRL's on all the time anyway.
However it has saved me on one occasion when l turned into an entrance and failed to see a low wall.
The Defender stopped itself and there was no damage. Except it was that close, when l reversed it pulled the lower front corner trim off. Fortunately the part only cost £85 and was easy to replace.
Post #1041743 3rd Aug 2024 8:48am
