![]() | Home > Puma (Tdci) > Thank you |
land 0068 japan Member Since: 27 Jun 2024 Location: kanagawa Posts: 11 ![]() ![]() ![]() |
Thank you
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 790 ![]() ![]() |
Again I'm replying not through any practical experience as I've not had the pump off the engine but I would have thought the oil is normal and that's how the drive is lubricated.. The pump has two connections.. On the landrover one is normally blanked.. Is yours??
I did check the pump on mine and I'll check to see what it pulled👍 |
It's pulling nearly a bar neg pressure👍
And you can see the brake pedal been depressed👍😂 ![]() Click image to enlarge |
