![]() | Home > Maintenance & Modifications > I have a hole in the wing! |
Daphne Member Since: 22 Nov 2023 Location: Kent Posts: 27 ![]() ![]() ![]() |
My 2015 puma has done the same, no mud behind it so it has just corroded through.
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
My 2008 has the same hole, have seen it on others of the same period. Assume it's a pressing defect.
Peter |
Put new panel on when I can be arsed 😂
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683 ![]() ![]() ![]() |
It’s very common, it is alloy corrosion, seen it for the past thirty years in front of the rear wheel arch where damp mud lingers. It happens too at the lower edge of the rear wing where the steel support touches the wing.
I’ve got very good at Tig welding them up and blowing over the panel. ![]() Click image to enlarge |
