Home > General & Technical (L663) > low speed stuttering
D200 3 litre
Hi, got a 2021 110 D200 3L diesel that splutters and is jolty at low speed, like when pulling off from a junction. Initially thought it was blocked fuel filter, changed that no difference. It is showing the engine management light on the dash and is going back to marshals p'boro for a new sensor. Unsure if this will fix the juddering, warranty just about to run out so want to get it fixed this time. Anyone else had this fault ? thanks
Post #1035717 26th May 2024 9:28am
Retroanaconda
Is it like a brief hesitation when pulling away at a slow speed, for example accelerating off a roundabout or away from a queue?
Mine had this, it was the exhaust manifold pressure sensor that was causing it. There is a thin tube which feeds the sensor and it blocks with soot over time. The dealer changed the inlet manifold sensor first but this didn’t fix it. I posted a thread on this forum with the error codes.
Post #1035729 26th May 2024 12:51pm
D200 3 litre
its more of a spluttering than a hesitation
makes the pull away jolty but could be the same fault
i've not looked at error codes, are they easy enough to see?
is there a link to your thread
Post #1035731 26th May 2024 1:28pm
Retroanaconda
You’ll need a compatible reader to see the fault codes. I use a GAP IIDTool.
Thread is here:
https://www.defender2.net/forum/topic90462.html
Don’t worry about your warranty, if the fault occurred before it ran out then they will still fix it even if it runs on beyond the end.
Post #1035734 26th May 2024 2:44pm
D200 3 litre
sounds like the same fault to me, i'll let the garage know when i drop it off
Post #1035759 26th May 2024 7:35pm
XplusYplusZ
There is a known gearbox glitch when you're slowing down close to a stop, then decide to accelerate again. Like you're slowing for a red light then it changes just before you completely stop. You push the accelerator and the car jolts forward..
I asked LR assistance and they told me it may be a software issue.
Post #1036171 31st May 2024 9:25am
