Home > Maintenance & Modifications > heated mirrors
jonny1966
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zermatt Silver
heated mirrors
bought a set of heated mirrors from mud stuff and just had them fitted.
need some bad weather to try them out
Post #100756 18th Nov 2011 6:16pm
They will be great had mine for a while now Thumbs Up
Post #100762 18th Nov 2011 6:44pm
I have them on my 110, used them the other week in fact; it wasn't frosty or remotely cold, but a damp misty day with drizzle. my mirrors kept fogging up.... 10 minutes, maybe 5 even, with the heaters on, and they were clear.
happy days! Thumbs Up
Post #100793 18th Nov 2011 8:26pm
markb110
I use Spafax heated unbreakable mirrors from Bearmach.
One less thing to worry about when greenlaning
Mark
Post #100806 18th Nov 2011 9:36pm
jonny1966
Well I got my chance this evening. Popped to the office then to the pub for a quick one. On the way back both mirrors are misted. As I always reverse in to drive I switched on the mirror heaters and hay presto I can see.
Great bit of kit
Post #101281 20th Nov 2011 11:35pm
ickle
Hi Guys,
what route do you use to take the cables?
On my 100" bitsa I drilled the door skins and put grommets in, through the A post and up into the dash etc, but with steel doors on the puma, I don't fancy that much.
I've already got convex heated mirror lenses on, but not connected yet..........
Keith
Post #101488 21st Nov 2011 10:50pm
T1G UP
can these be wired in to the front screen switch?
first mod as these damp mornings and my location means misty windows and mirrors for months now
Post #102691 26th Nov 2011 9:11pm
Yep that's how I've done mine
Post #102693 26th Nov 2011 9:16pm
jonny1966
had mine wired to rear screen heater plus on a relay
Post #102694 26th Nov 2011 9:17pm
T1G UP
straight off Ken or through a relay etc?
not got a clue about electrics!
Post #102695 26th Nov 2011 9:23pm
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Fitted mine today, straight from the heated windscreen. Mark
2011 110 XS DC
Stornoway Grey
Post #102697 26th Nov 2011 9:37pm
T1G UP
cool, which ones dd you buy? i'm looking at the RDX ones on ebay
Post #102698 26th Nov 2011 9:39pm
dgardel
Italy
Where do you routed the cable trought the door? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #102699 26th Nov 2011 9:52pm
MuddyMarky
Exactly the ones I got - fairly straightforward to fit, I just used the heated windscreen cable on the left hand side of the screen (the purple one), and an earth from of the bolts in the same area. Mark
2011 110 XS DC
Stornoway Grey
Post #102754 27th Nov 2011 11:05am
MuddyMarky
I spent a bit of time looking at this, and in the end, after lots of testing things out (didn't really want to strip the interior door trim/panel out), I routed the cable from behind the hinge, straight across the rubber seal, with a small amount of slack.
I know some on here will frown upon it, but I did a fair bit of checking/rechecking that it wouldn't get damaged/leak water in - the cable now sits nicely in the soft part of the door seal, not being pinched at all, but allowing the seal to form around it when the door is shut. Then I secured the cable inside the cab, so neither 'side' of the cable (inside & outside) would move at all. I was extremely wary about drilling any holes in the bodywork following the fitting of a RAI on my 90 last year that I just couldn't solve the leak afterwards. The cable is visible when you open the door so I'll just keep an eye on it. Mark
2011 110 XS DC
Stornoway Grey
Post #102756 27th Nov 2011 11:10am
