Home > Technical > Defender td5 play in turbo? Bad sensors?
Djmdaniel
United Kingdom 2002 Defender 90 Td5 SW Aintree Green
Hi, my defender td5 2002 90 struggles on acceleration and its hard to get it above 65
Just trying to figure out why at first the E pin on the boost waste gate was misidentified so i thought it could be that but that hasn’t changed anything so iv removed the pipe and this is how much play is in the turbo?
https://youtube.com/shorts/RiOVoXMCk6Q?si=RBrYZYcsiU8VukQ3
Is this normal and would this cause a lack in power when accelerating?
The problem of the lack in power started after I had my clutch and flywheel changed, at first i thought it was the crank shaft position sensor+ cables as I could see a bit of damage on them, so i fitted a new sensor and cable loom but this didn’t change anything, any ideas of anything other sensors that could have gotten damaged? Thank you
Post #1032974 26th Apr 2024 7:45pm
landy andy
That turbo has more play than I would like, but I don’t think that is the lack of power you are getting. It may cause smoke.
Can you see any damage to the fins of the turbo?
Assume it spins freely.
Post #1032983 26th Apr 2024 8:43pm
Djmdaniel
No damage and it spins freely
Post #1032984 26th Apr 2024 8:46pm
landy andy
Obvious but I will say it.
You aren’t stuck in low on the trans box are you?
Post #1032985 26th Apr 2024 8:48pm
Djmdaniel
I can hear it go from high neutral and low and low feels like it’s in low and high in high if that makes any sense
Post #1032986 26th Apr 2024 8:49pm
