Home > Puma (Tdci) > Factory Carpets - a few questions |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 160 |
Probably no help, but I fitted Lucari carpets in mine as the LR ones seemed cheap. If you get a refund they are worth a look.
I only glued mine where it’s unlikely to need lifting again (could be anywhere on a defender I suppose), for the rest I used professional grade carpet tape and it’s all still where it should be. |
2nd Apr 2024 7:38pm |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 105 |
Thank you JoolsB for your input. I think the wheel arch parts are stuck down from the factory and the rest just sits there.
I read some reviews on Lucari carpet not fitting that great etc hence going with factory. Yes, it would have saved a bit of dosh for sure |
2nd Apr 2024 9:49pm |
